Enscape no longer respects SketchUp scene FOV when rendering a single image
Hi there,
Since updating to 4.19.0.2784, Enscape no longer respects SketchUp scene FOV when rendering a single image with Synchronise Views enabled; it reverts to the Enscape FOV. Before pressing Render, the FOV in the Enscape window is as per the SketchUp scene; during the render the FOV changes to something else and after the render is complete, the behaviour returns to what’s expected. I also have the Safe Frame enabled. Within the Enscape window’s View Management tab, I have no Linked Visual Presets.
I’m used to this behaviour with the batch render, but this is new and appears to be a
@Pete_Allely - thanks for reporting this - it’s a known issue in Enscape 4.19. Our developers are already investigating and we hope to be able to deliver a fix in our next version. If it’s a blocker for you, you can switch back to 4.18, where the issue is not present. Sorry for any inconvenience!
@Pete_Allely The new version of Enscape, which contains the fix for the issue you reported, is now live - you can download it in your Chaos account.
