I deleted this object in SKP but it still appears in Enscape. I have restarted it and it does not go away in Enscape? See images
Hi @dvsone1440
That is odd indeed, can you verify that the object is also not showing in SketchUp when choosing Edit > Unhide > All
If it doesnāt, are you able to share the project with us so we can further investigate this issue?
If so, I have sent you a DM with a link where you can upload it to.
Yes Checked hide layers etc.. I will send the file.
THanks
Could it be you deleted the contents of the component but not the component itself? So you have a (near) empty component?
The only scenario I could think of was someone had deleted the shape inside the enscape component (I have young staff working on this model⦠so possible) but I tried a test and if you open the asset component and delete the generic shape, it seems to disappear in Enscape as well. Which surprised me.. I thought it might stay but it does not.
Hi @dvsone1440
Thank you for sharing the project.
As a quick fix, you could delete the asset by opening the Asset Library in our viewport, select the asset and use the ādeleteā button on your keyboard.
So far, I was also not able to figure this out either, but will have another look at this and perhaps include our developers to see what may have caused this, or if we can prevent this from happening again.
I will keep you updated.
Great thanks for the update. I was baffled but did not know deleting it in the library was an option thanks.
I recently had a user with a similar issue, but in Rhino. There is a āmysteryā tree that appears in Enscape, but not Rhino. And two that appear in Rhino, but not Enscape. If I delete the two circled in red, it gets rid of the one circled in blue.
I have replicated on a couple machines using both local and cloud asset libraries. Tried clearing Enscapeās data cache. The single tree in blue is selectable in the Enscape window, but after deleting, it gives an error message āunable to apply changes.ā Iāve pasted the relevant elements into a new file, attaching here.
tree asset test.zip (581 KB)
Morning, @dvsone1440 , glad that worked for you as well!
@rifkin , would it be possible for you to share this (test) project with us as well, perhaps this is related and in dsvoneās project the actual asset was also in a different location in SU.
If that would be possible, I have sent you a DM with an upload link as well.
Hey @dvsone1440 and @rifkin
Our developers have taken a look at this issue, and our assets in the CADās are usually just an object with our asset id which is an instance of some sort of re-usable component/definition/symbol that holds the placeholder geometry. This also means you can change those instances and those definitions.
They think what happened here is that either the reference to the definition or the definition itself got modified so that an empty object with just the asset id was left over. They would suggest the same action that I mentioned above to delete the asset from Enscape in such cases.
This isnāt a bug but just how our asset system works.
Fwiw, I think this is a good thing. Weāve used the ability to edit the guidās many times, and it enables workflows that would otherwise not be possible (for example, have a checkbox in Revit that says ārender as assetā or ārender as placeholderā.
Thanks for looking into this. I will try that solution.
Hi, how did you find the exact guid for a specific model in sketchup? I would like to locate an assetās texture but in sketchup I donāt see any guid related stuff on a group object or component object as well. Could you please show us some images where I can find the guid? thanks
I was referring to Revit. Iām not sure if the guidās are exposed in the Sketchup UI.
