I am using Enscape for Rhino and never had this issue before but the preview image shows a bright scene and when I hit render to save it, it turns dark and brown. What is causing this?
@Angela_2 , pardon the delayed response. The preview image may be that bright because there may be light leaking into the scene from the outside - at least by the looks of it this could be the case so please briefly check out this article here too to read about some provided workarounds that you can implement. In the meantime, I reckon it does help when you (disable Auto Exposure and) increase the Exposure before rendering?
