Enscape refresh SU hide/unhide objects between scenes
Hi, however I’m not a SU user (more Revit), I have a question from our design team: in our models we have scenes, interior (with ceiling unhided/layer on) and birdseye view (with ceiling hided/layer off). The question is that Enscape does not follow the hide/unhide state if we are switching between scenes → only when I make a SU command, for instance move from another object a little the scene does refresh and pic up the state of the hide/unhide - layer on/off ceiling… What do I do wrong?
Tnx, Remco
I can confirm this bug as well
Entities hidden by layer via scene change are not being updated properly.
Hello @RemcoNL_1 , hello @adam_hails ,
indeed, Enscape doesn’t support switching Layers / Visibility based on Scene transitions at the moment. We’re aware of this and are looking forward to resolving it as soon as possible!
Just a note on this topic, this applies also to scene states of section planes that are turned on/off by layer.
A workaround we have found is to just click the play button again on the enscape toolbar.
@vertigo1_1 Can you tell me how to turn section planes on/off by layer in SketchUp (no Enscape involved). I can’t reproduce this - only able to show/hide the plane, but the part that is cut by the section plane is always hidden in SketchUp. Also you can’t mean the toggle in the menu “View->Section Cuts”, because then using the Enscape play button would not help. If you can provide me with a test project, that would be great. Thanks.
They were hidden and unhidden by scene, not by layer. I had a misunderstanding of how the scene states in SketchUp work.
