Enscape´s Line Lights - Help needed
Hi Everyone - I still have no idea how to align an Enscape line light to any given modle edge but constantly fail on Enscapes so extremely awkward and for me so strange light-adjustment gizmo.
Shouldn´t it to be assumed that simpliy clicking the points of a given line should be logical - not for Enscape! :wink: . Since there is already a rotation tool, why can’t I just enter a desired rotation numerically? You see - I have no clue !!! :slight_smile:
So, maybe there is any informative tutorial? I am happy about every instruction :slight_smile:
Enscape lights are a chore to place, the placement procedure itself is somewhat obscure plus it doesn’t even adhere to things like axis locking in SKP which might make it somewhat tenable. What I did is to prepare premade lights packed into “Glue to”-components that are way easier to place and then use the SKP moving/rotational tools to get it into place.
+1 - in sketchup, light placement is very cumbersome and there must be a simpler way to generically place lights and adjust after. Adding more intuitive “grips” and adding XYZ coordinate system input boxes into the Enscape Objects Dialogue box, would solve this.
Thank you both and for your suggestions and this little insight into your smart strategy MatthiasL :thumbup:
I am glad to know that others feel the same as I do :wink: Yes, the sum of nonsensical and illogical clicks for placing light sources is an insult ;(
I do want to say that I think this is an issue with the spot and rectangular lights as well; all of these objects need an overhaul.
Agreed. my workaround for this has been the use of emissive materials which seem to work pretty much as well as lights.
I found using only emissive materials for illumination to be somewhat finnicky, so I’m curious what’s your approach? Just slap emissive materials anywhere you need them?
I second using pre-made light components, makes it much easier to drop and place.
… which is a good strategy with SketchUp logic which I use exclusively by now :wink: (after MatthiasL helped me out of my thinking blockade :wink: )
