Looks like since the last update the general settings pop-up is crashing when used.
Anyone else has this problem too ? My scene is only 18 MB.
The pop-up with the settings does appear, but when I move a slider my whole sketchup scene is “not responding”.
The dropdown list does not appear at all.
After a lot of patience (a few minutes), the changes have effect en it takes about a minute to close the pop-up again.
Hello @Vendel3D , which slider causes the crash?
Every slider. Don’t think the problem starts with one particular slider. Everything I click on in the settings menu, causes the “lag”.
@Vendel3D okay thank you for the information. Did you send crash dump when it crashed? If not, please do it so we could have a look.
Hi, I just installed enscape. I have SU 2017 Pro. When I press start enscape it starts loading, there is screen to chose evaluation and there is a crash. Sometimes just enscape crashes, sometime SU crashes also. It doesnt matter if its a big file, small file or just empty skechup file. I also cant send report it just continues spinning. Please help. I need to convince client to buy the licence!
@wizualizm you can find logs and probably crash dumps in C:\Users*YourUsername*\AppData\Roaming\Enscape\Data\Logs directory. Please zip and send me the contents via PM so we could check what’s wrong.
Thank you Alexander, I have attached some of them here. Looking forward to hear from you.
Logs.zip (1.52 MB)
logs2.zip (1.54 MB)
logs3.zip (1.32 MB)
Looks like I’ve solved my problem.
I think my sketchup’s field of view settings were out of their boundaries.
Therefor, the field of view settings in Enscape were not correct too.
I’ve pressed the reset this tab button on the general tab, and turned my Sketchup fov back to 65.
Now everything is just working fine again.
Is it because Intel Integrated Graphics is not supported?
@wizualizm Intel cards are not officially supported. Although in your case Enscape seems to crash because of the memory allocation issues (are you out of RAM when starting Enscape?), I’d recommend using Nvidia/AMD graphics card to be sure that it will work.
@Vendel3D glad to know your problem is solved! Although I cannot reproduce the bug. Which FOV setting did you have in SketchUP that crashed Enscape?
@wizualizm Officially not supported means we cannot guarantee that it will run on an Intel GPU (although sometimes it does). We don’t restrict Enscape from running on Intel GPU artificially - if GPU is able to run it, it will do. Logs and crash dumps didn’t give very detailed information - application crashes because it cannot allocate memory. It may happen due to the number of reasons and first thing to do is to ensure that you have compatible hardware - GPU in your case.
Same here guys, Settings LAG a looooooooooooooooooooot, my fov was 70’. I reseted the tab and works fine.
Conflict between Sketchup and Enscape FOV possibly.
Sketchup 2017
plugin version 2.2.18113.742
Enscape version: 2.2.3.4.-g070c5ba
@pkarpiozo Glad to hear that resetting the settings worked for you as well. Have you sent in feedback via the [Feedback] button before you’ve reset the settings?
Hi! I downloaded the trial version today and installed it but it shows my trial version expired (00 days) of trial version. Could you help me!
I’m sorry to hear that - You may have acquired and installed Enscape on that machine in the past I reckon?
In any case, you can request a trial reset as detailed here:
RE: Enscape Free Trial Expired? (Please see last reply)
Let me know if any further inquiries come up.
