Hi all,
I have just updatedmy Enscape version and working with Rhino with a previous version of Enscape 2.8 I have saved some settings into the project.
Opening the same project with the 3.0 version I can’t see the settings previously saved. Is there a way that I can recover those?
Thank you in advance.
Hey @Andre91 , I’m sorry to hear about that - the settings saved into your project should still be available. Have you double-checked the actual new settings area itself, just to make sure:
If you cannot find any of them in there let me know!
Hi @Demian_Gutberlet , thanks for getting back to me. Yes I have checked that area too but unfortunately it seems that they are gone. I also tried to downgrade to 2.8 version but nothing there as well. Luckily I had a similar settings saved externally.
That is unfortunate to hear, but I’m glad that you were able to mostly recover your work already. If you like we can troubleshoot this further, or you can get back to us in case you ever run into this or a similar problem again in the future - this is generally something that should not happen again, so definitely let us know if it occurs once more.
