I am using Enscape latest edition for windows,
I am encountring rendering defects, the shadows of previous elevation stays & doesn’t turn off,
each elevation is independently modeled no shared surfaces or planes,
exterior.pdf (7.29 MB)
It is quite normal for shadows to stay.. for a few seconds, depending on how big is the model.. Does clicking on Start ENScape button refresh shadows.. You don’t have to close the render window.. If it is already open “Start ENScape” works like reload.. It is not ideal to reload after every change of view but might help till tech team will help better..
Do You have enough memory?
Hi @HazemZ
are ray-traced sun shadows enabled in your Renderer Settings?
If yes, can you please try turning them off and see if the false shadows persist?
Thanks!
@tomasz_drgas thank you for your suggestion, it works for screenshot saving method, but when batch rendering is used, it is the same results, as for memory I have 192 GB & AMD 64 core 3.1 GHz
@Clemens_Musterle , would you kindly tell me where is that setting, thanks
