Enscape 'steals' rhino named views, and crashes rhino when trying to delete any views
Please see this thread in Rhino forum:
https://discourse.mcneel.com/t/bug-deleting-named-views-crashes-rhino/91548/3
Rhino6 crashes when deleting named views that were saved using the rhino save named view tab.
When Enscape plugin is blocked from loading the named views dissapear, as if Enscape has hijacked the named views
please look at this issue and try to find a solution,
yrs,
a
Thanks a lot for your report - in this case we’ll also require a dedicated feedback report which you can send in as described here. That would be very helpful in order to troubleshoot the cause behind this issue. In the submission form, please also add a link to this forum thread for reference. :slight_smile: Thanks again in advance!
