Enscape support for ArchiCAD 29
ArchiCAD version 29 is coming soon.
Is there a quick update planned for Enscape to support it?
Francesco
:archicad:
Also wondering the same, about the update or compatibility with Enscape actual version with Archicad 29…
Actually 29 is out now, tried and its not possible to install Enscape on it… Any news on when will it be available for Archicad 29?
Cheers
Hi @usa and @joo_mouro , to provide you with a current update: we are targeting support in our next full version of Enscape 4.13, which is set to release at the end of the month. I’ll make sure to update you once more via this thread after said release itself.
Thank’s Demian for update
Francesco
thank you @Demian_Gutberlet
Looking forward to it. I’ve become so dependent on Enscape that I’m not using ArchiCAD 29; I migrated a few projects only to go back to 28 while we wait.
I also thought about it but BIM spoke louder… I’m already using 29 but eagerly waiting for the Enscape version for Archicad 29… :slight_smile:
Cheers
Appreciate the update on the upcoming Archicad 29 compatibility with Enscape 4.13. I’ve been testing the recent previews 4.13.0.516 Preview 1 (and Preview 2) and wanted to let you know that the Enscape menu isn’t showing up in my Archicad 29 setup. Just reporting
Preview 2 is not for AC29, only for AC28. Only at the end of this month will come out a version for AC29 as stated by @Demian_Gutberlet
Cheers
Enscape version 4.13.0.619 is just released and is very buggy and is not at all compatible with Archicad 29.0.1 Version on macOS 15.7.1
The issue I face is very annoying and is as under:
1. When we try to access pull down menus, while Enscape render window is active, the pull down menus appears to be blank momentarily and then the blank square of pull down menu remains as it is.
2. The most annoying part is, such Blank squares of pull down menus also remains as it is, even when Archicad 29 window is active, hiding everything below it. These blank squares do not go away, even when clicking on it, minimizing the archicad window and then maximizing it, making it impossible to work in Archicad 29.
  1. Only work around, I have found out is to close the Archicad application and again opening it. The issue again restarts, when we start the Enscape again.
4.This issue does not happen with Archicad 28 with Enscape version 4.13. This latest Enscape version works perfectly fine with Archicad 28.
5. I am attaching the screenshots of the issue for better understanding.
Is there any update on this please? The last version I have still shows the blank panel on MacBook Pro
Hi @KCArch , and welcome to our forum.
Right away, just in case you haven’t already, please make sure that you’re using our most recent macOS release found here.
If that makes no difference, and especially since AC 29 should be fully supported with said most recent release, please kindly forward this behavior to our dedicated support team directly as detailed here, and we’ll troubleshoot the exact cause behind this behavior and get back to you via the corresponding case created by then.
Thanks a lot in advance.
Hi Damian,
me again… I’m on the latest version, using AC29 and Enscape 4.15.0276 on Mac M3 max.
It seems there is no way I can create a nighttime render, the ArchiCAD sun doesn’t sync, the the keys U/I or shift+right click and move mouse doesn’t work, I cannot seem to have nay control overate sun. What am I missing?
Testing a brand new ArchiCAD file with just a couple of elements, everything works as it should. The sun in Enscape reacts to keys, mouse movement and syncs with the AC sun too. it seems there is an issue with the project file. Any idea what should I look for?
