Enscape-type Materials don't display in Rhino render viewport
Hello there! New to Enscape :stuck_out_tongue:
Here is my situation, and hope someone might know the solution ;( :
My friend and I are working with Rhino 6+Enscape 2.9 on our own different computers for a same file. On my computer, if I set one object in rhino with a material which is Enscape type, normally it will also show the material texture in Rhino render viewport ('cause we like to check and adjust the design in rhino directly). But once I save the file and open it on my friend’s computer, the material won’t display in Rhino viewport anymore, but it is still there and everything displays normally inside Enscape window. vice versa
Does anyone know how to fix this? I have also attached two images to explain it better.
Thanks in advance! 8|
Hey @yZangwill , thanks a lot for your report and welcome to our Forum!
I’m afraid, at least at the moment if you move the project from one machine to the next the image files are not automatically re-linked, only if you’re using the same directory for those files by utilizing a shared network drive for example. Still, since Enscape seems to display the materials still, is there a chance you could pass over the project so I can have a look at this myself? Alternatively, could you send me a screenshot of those materials how they appear in the Enscape Material Editor? Do you see any missing image files for example inside that editor?
Thanks a lot in advance!
