Enscape v2.7.2 ribbon doesn't fit the window on full screen
Any idea why the enscape ribbon doesn’t fit the window on full screen? Seems to carry on beyond.
Can anyone help with this issue?
Danyal
I’ve had the same thing. I’m not sure there’s a real solution, but as a workaround you can make the window of revit smaller until the ribbon reorganizes.
Can anyone from Enscape help with this?
Thanks for your inquiry - could you try turning off the window scaling, if you have it enabled:
Should it not be enabled at all, please get back to us and we’ll investigate further.
