Enscape water doesn't animate when I turn it vertical
I am trying to create a water feature wall for a restaurant I am currently rendering. The enscape water works perfectly fine when it is laying flat on the ground but as soon as I turn it vertical for the feature wall, it stops rendering/animating like water and instead turns a weird reflective blue color or will just look like glass. Any ideas on how to resolve this?? Thanks!
@cchutt , welcome to our Forum.
Vertical, correctly working water is not supported by Enscape I’m afraid - You can forward your request directly to product management too through our portal, but at the moment this would only be possible with workarounds, of which there aren’t unfortunately many in this forum either as it is not that easy to achieve.
Still, we appreciate the feedback of course.
One thing I’ve been able to do as a workaround is add a bump map to a glass-like material to represent a waterfall.
I did the same thing - just added a rain glass texture to glass. I wish there was movement for my video, but the result looks pretty good to me.
