Enscape won't be enabled in Rhino 5.0
I just installed Enscape with the 14-day trial. I tried to enable it on Rhino 5 and was unsuccesfull, on my setup app it says that the version is only available for Rhino 6 and 7.
Is there any way I can get the version for Rhino 5?
Welcome to our Forum.
You may be able to make Enscape and Rhino 5 work by using an older version of Enscape, but we cannot really recommend it as you’ll miss out on quite a few added features from the past years, plus we cannot offer any official support for these previous releases anymore. We thus highly recommend upgrading your Rhino to 6 or 7, perhaps that is possible for you.
Thank you for your response!
I am going to upgrade the software.
Hi, I am using Rhino 5. Is there a way I can use enscape?
As mentioned in my reply above, you may be successful using an older version of Enscape, but we instead highly recommend upgrading your Rhino to 6 or 7 instead. You will otherwise also not be able to make use of all the newly added functions from newer releases.
