Enscape won't completely load
I downloaded the most recent version and am trying it for the first time now (for a project that is due today!) When I launch the program, I get the usual Enscape laoding screen (see screenshot) but it never completely loads…it just keeps spinning and this screen continues. I’m using SketchUp Pro 2019.
Is this a known issue? I’m on a deadline…can I remove this and go back to the last version.
I’d appreciate some quick help! By the way…I also found just connecting to your site and navigating through to be incredibly slow today..
Diane Dieterich
Just tried to close and relaunch again, and now Enscape won’t even launch.
Double help!
Tried a third time (this time with a different, very small model and got this error message (see attachment)
I’M HAVING THE SAME PROBLEM, SO I RESTORED THE PREVIOUS VERSION
We’re seeing the same behavior here – All machines hang up with the splash screen. We have multiple workstations, with NVIDIA and AMD cards, and they all have some version of this behavior, which began this morning.
Same issue as original post. Enscape just sits at loading screen. If I kill this screen and try to restart Enscape won’t even launch the loading screen. Was working fine end of Dec. around the 19th. I’m on SU Pro version 19.3.253 64bit on Windows 7 Enterprise SP1. Enscape version 2.6.1+1326
I also just tried to uninstall and reinstall and problem still exists. I also tried moving back to 2.6.0 and that didn’t work either.
Update, some of my older models load into Enscape fine but the latest couple of projects have the issue.
It’s an issue with assets in the asset library. If I wait long enough I get the attached error (similar to dldieterich2) and Enscape will finally load. I can also turn off the layer that has all of my Enscape Entourage and Enscape will load the problematic models.
To anyone who is experiencing these issues, kindly refer to this thread right here. As we mention in the thread, we’re actively working on resolving this issue as soon as possible, with utmost priority of course.
What is the workaround for now? Can I revert back to an earlier version? Can’t seem to find that on your website.
https://enscape3d.com/version-history-preview/?fbclid=IwAR3fFlMc1CU0aRxpZGAmZSosMVe7miZCxVn4mNc-mQonGGS_Js0Q8FRL-0Q
https://enscape3d.com/download/
Hi all! Please be so kind as to refer to this thread for our current workaround; at this time the only workaround we can suggest is to remove any Enscape assets from your project (or simply hide them).
