Enscape works in Rhino 5 but not in Rhino 6?
Good afternoon,
I’m using Enscape for the first time today, I installed it for Rhino but I can only locate the Enscape tabs in Rhino 5 and not in Rhino 6 - I have gone through the instructions here - https://enscape3d.com/knowledgebase/getstarted/ - the menus are not showing in Rhino 6, please can you advise.
Thank you
Martin
Hey @mart433 , thanks a lot for your post. Enscape fully supports both Rhino 5 and 6, 64-Bit.
In this case, what you can try first off, is uninstalling Enscape completely, and reinstalling it again using our latest installer.
If that doesn’t help, could you please go into the “Properties” of Rhino, click the menu point “Plug-ins” and have a look if you can find and/or enable “Enscape.Rhino.Plugin”. If it’s enabled just fine, please go into the “Toolbars” section in the Properties menu and make sure to enable the (or some) Enscape toolbars as well:
Thank you very much in advance! Let me know in case this procedure doesn’t help. :slight_smile:
It worked, the Enscape plugin was showing under plug-ins but was disabled - Thanks for your help Demian :slight_smile:
Awesome! You’re very welcome. :slight_smile:
