Ensure Uninterrupted Access To Your Chaos Licenses
(Please note: You may have already received this information below via a dedicated separate e-mail we’ve sent out alongside.)
Dear Forum Community,
We wish to share this important update to Chaos Licensing as the server certificate will expire on January 28, 2025.
To ensure uninterrupted access to your licenses, you must update your Chaos License Server by January 28, 2025. Failure to do so will result in the loss of access to your licenses.
What you need to do:
  • Option 1: Update the Chaos products you are using to their latest versions. Your Chaos Licensing system will update automatically.
  • Option 2: If updating to the latest version isn’t an option, you can independently update the license server by following this detailed guide.
Thank you for your cooperation! If you have any questions, please don’t hesitate to contact Chaos Support.
- The Chaos Team
I saw no mention of the Linux license server in the linked docs regarding the updates. Is it safe to install the new version over the existing version on Linux? Have there been any library version requirement changes, or did the new version run anywhere the old one did?
Thanks.
Hi Joelaff,
Yes, you should be okay installing the new version without any problems. If you need assistance, please open a ticket in our system. Thanks!
so if i understand this correctly, installing newest Chaos License Server is enough to avoid the problem. Is that correct?
Yes, that is correct.
Thank you :slight_smile:
One more question before we do this… Running on linux here-- if it matters…
Do we need to return any offline licenses before upgrading the server? Or can we just run the new installer and they will continue to work properly?
We always keep licenses checked out for offline use (on the server itself) so that there are no issues in the event of an internet outage on our main and backup connections. (You’d be amazed how multiple providers share the same fiber many places and a backhoe can cause a really bad day.)
Thanks.
Always release any borrowed licenses before updating/re installing the license server.
I have a permanent licenses so i can ignore this, right? Hope so!
Or do I need take care of something ?
Your license type is irrelevant. You need to have license server 5.5.6 or 6.1/6.2 installed in order to continue using your licenses. Versions 5.5.5 or below or 6.0 will stop working. They are already removed from the download page.
I don’t have access to my computer. I’m not using vray at the moment, is it fine for me to do this when I do have access after the 28th?
Yes, you will just need to install the latest license server (if you don’t have it already) when you have access to your computer.
Additional information for those interested on the forum
The certificate for ols.chaosgroup.com will expire at the following times:
Tue, 28 Jan 2025 12:06:01 GMT​
I am currently running License Server 5.4.0 as a service on a Windows server.
I have just been alerted to the fact that this needs to be updated to 5.5.6 by 28 January. However when I try to install I receive the error:
Incompatible CPU detected! Missing instruction sets: SSSE3, SSE4.1, SSE4.2
The server has an AMD Opteron CPU. I will not be able to provision new server infrastructure before 28 January and so will need an alternative solution.​ It does seem odd that a licensing agent has specific CPU requirements. I have opened a support call.
Support have confirmed that this no alternative. I need new server hardware and to reconfigure all my clients within a week.
This could have been handled so much better. With at least a reasonable amount of notice for large organisations. How about back in June when I renewed my licences? :rage:
What about V-Ray version and MacOS version compatibility? My current subscription on my main machine has 6.1 Server on MacOS Ventura 13.7 which is OK as I understand it, but what about my legacy version 5.2 V-Ray for SketchUp on a legacy machine running Montery 12.7? Does that get 5.5.6 instead? Is there any compelling reason to upgrade Server 6.1 to 6.2?
If you have 6.1 you don’t need to do anything. On your old machine go to http://localhost:30304/#/about and check the version. Its most probably older than 5.5.6 so it will require an update.
