Environment Fog, 3D Textures and Invalid Color
Hey,
the Problem is gone (it seems). The Meshlights were the cause. However I can still force it, when I put in a Noise Amplitude, higher than 1.
Next question. :slight_smile: Sorry, if this is getting quite long, but I’m still learning.
What do I have to do, if I don’t want my fog to be cut off straight by the fog height value? I tried mapping it but it doesn’t really have much of an effect (maybe I’m doing it just wrong…). I want a cloudy, wispy feel to it at the top.
It looks fine from a steep angle:
However, with a more horizontal angle, it looks like this:
Hopefully, it’s done after this one :slight_smile:
Kind Regards,
Sebastian
You could use a gradient ramp or something to fade the density. However if you look at the fog in the infinity it is always going to be a straight line unless you are a little bit inside the fog itself.
P.S. Mesh lights were one of the problem; negative values in the Noise texture (when the amplitude is pushed beyong 1) was the other. They should both be fixed in the build I sent you.
Hey Vlado,
thanks a lot! The build fixed it. Both issues. :slight_smile:
I think I will have to find another solution for the fog, though. Unless someone has a great tip for me. :smile: I have a 3D solidFractal in the density slot already; I tried tweaking everything by now, however I can’t seem to get the top broken up into wispy shapes.
Kind Regrads,
Sebastian
Like I said, raise the fog to include the camera…
Hey,
the invalid color error is back, even with the new build. Once I try to precalculate Light Cache with 5000 subdiv with primary and secondary engine set as Light Cache, and set to fly-through, I get loads and loads of invalid color errors. When I try to reuse that precalculated LC I get black spots scattered through the whole scene. I tried isolating it, however had no luck, since it seems really random. There is no fog or 3D texture in the scene. Do you have an idea, what could be the problem?
Invalid Color
Kind Regards,
Sebastian
The strangest thing is, that single frames render fine, I even rendered about 90 frames, they were fine also. Should I send you the whole scene? (quite big)
It will be helpful; otherwise I don’t know what else might be wrong.
I managed to break it down a bit and sent the scene to your email adress. : )
Kind Regards,
Sebastian
Any news on this? I fixed it using a frame from the beginning with the same settings for the LC file, i don’t know however why this would make a difference. Would be nice to know what was wrong… . :slight_smile:
