Environment fog has changed functionality
Hi All
I just loaded up an old scene from 2021 that was using Vray 5. When rendering using Vray 6 things looked very different. I looked into the issue and found out this:
In Vray 5 you could not include a light in the VrayEnviornment fog nodes but still get the fog on the GI bounce from the light. This could produce beautiful and subtle fog without the harsh beam from the light itself. In Vray 6 now with the option to Affect Atmosphere on each light this doesn’t seem achievable. The lights bounce no longer effects the fog when it isn’t selected.
Does anyone know if this is achievable in Vray 6?
Sam
HI, thanks for posting. If you want only the GI from a light you could use the ray filters:
Hi Thanks for your reply Vladimir. Unfortunately I dont think any combination of these works. If there was a ‘GI only’ option then yes.
Hi, what version of V-Ray are you using? I checked the V-Ray 5 update 2.1 here and it is the same as V-Ray 6? Could you also show us a example of the effect you are after and if possible a test scene?
Hi, excuse me but I am still not able to reproduce your setup. This is what I have now in V-Ray 5:
I have VRayLights and the settings are as you said but the render is black
This is what happens if I enable “use all lights”
Lights start to appear in the fog as expected.
The same is with V-Ray 6.
Hi Vladimir - OK When opening the scene in Vray 6 some "<deleted>’ lights appeared in the Fog nodes Gizmos and lights. I dont know why as there was nothing in the Vray 5 version - having removed these the issues went away! - So sorry but I dont know what was going on…thanks for your time.
Hi, thanks for confirming and for keeping us posted. I am happy that you are up and running.
