ive put a background plate in my render set to screen projection.
as usual, i set the gi/reflection and refraction overrides to black so the (bright yellow) background doesnt affect my render…
it quite clearly still affects my render!
this is on CPU so its not any Gpu wierdness.
appears to be related to "matte for refl/refr. on ground plane.
when its enabled , Max environment shows in reflections etc, even if its overriden in vray render settings.
i would imagine that setting should respect the overrides in the scene?
