Environment question
Quick question. Do Vray lights block the environment light when placed in the windows ?
Regards,
Mike
yep pretty much.
Even if its “invisible” it will block the environment light completely.
Turn it off or delete it then the environment light comes flooding in.
Thanks…I new something wasnt right.
You could use 2 vray lights.. one a the front set to Skylight portal and the one behind it as normal.
That should work :slight_smile:
