We’re experiencing an issue with Phoenix for 3ds Max 2026 after performing a command-line installation. The environment variables PHX_FOR_3DSMAX2026_BIN and related Phoenix variables are not being set properly.
Error Message:
The PHX FOR 3DSMAX2026 BIN environment variable can not be found. Please reinstall Chaos Phoenix!
Setup Details:
- Installation method: Command line installation
- Software: Chaos Phoenix for 3ds Max 2026
- Issue: Environment variables missing after installation
Has anyone encountered this issue with command-line installations? Are there additional steps required to properly configure the environment variables when not using the GUI installer?
Any help or suggestions would be appreciated.
Installation Command and Config.xml File
phoenixFD_adv_52400_max2026_vray7_x64.exe -gui=0 -configFile="config.xml" -quiet=0
<DefValues>
<Value Name="CGLS_INSTALLED" DataType="value">0</Value>
<Value Name="PKGROOT" DataType="value">%ProgramData%\Autodesk\ApplicationPlugins\Phoenix3dsMax2026</Value>
<Value Name="VISIT_DOCS" DataType="value">0</Value>
<Value Name="PROGRAMFILES" DataType="value">%ProgramFiles%</Value>
<Value Name="STD_LEGACY_DETECT_ROOT" DataType="value">NOT_INSTALLED</Value>
<Value Name="RTROOT" DataType="value">1</Value>
<Value Name="ASSOCIATE_AUR" DataType="value">1</Value>
<Value Name="ALLUSERSPROFILE_ENV" DataType="value">%ProgramData%</Value>
<Value Name="PROG_ID_NODE" DataType="value">ChaosPhoenixNodeViewer3dsMax2026forx64</Value>
<Value Name="COMMONFILES" DataType="value">%ProgramFiles%\Common Files</Value>
<Value Name="PROG_ID_PRV" DataType="value">ChaosPhoenixPreviewer3dsMax2026forx64</Value>
<Value Name="PKGROOT_SELECT" DataType="value">0</Value>
<Value Name="OPEN_CHANGELOG" DataType="value">0</Value>
<Value Name="REMOTE_LICENSE" DataType="value">1</Value>
<Value Name="SHOULDUNINSTALL" DataType="value">1</Value>
<Value Name="ASSOCIATE_F3D" DataType="value">1</Value>
<Value Name="INSTALL_TYPE" DataType="value">0</Value>
<Value Name="ASSOCIATE_VDB" DataType="value">1</Value>
<Value Name="ALLUSERSPROFILEPATH" DataType="value">%ProgramData%\Autodesk\ApplicationPlugins\Phoenix3dsMax2026</Value>
<Value Name="ASSOCIATE_PRT" DataType="value">1</Value>
<Value Name="STARTMENUPROG" DataType="value">%ProgramData%\Microsoft\Windows\Start Menu\Programs</Value>
<Value Name="PHXROOT" DataType="value">%ProgramFiles%\Chaos\Phoenix FD\3ds Max 2026 for x64</Value>
<Value Name="MAXROOT" DataType="value">%ProgramFiles%\Autodesk\3ds Max 2026\</Value>
<LicServer>
<Host>server.home.local</Host>
<Port>30305</Port>
<Host1></Host1>
<Port1>30304</Port1>
<Host2></Host2>
<Port2>30304</Port2>
<User></User>
</LicServer>
</DefValues>
