Envision x Revit 2027
We are currently upgrading to Revit 2027, but we are unable to install Chaos Envision because the latest available version is only compatible with Revit 2026. Could you please let us know when an update for Chaos Envision with support for Revit 2027 is expected to be released?
Thank you in advance for your response.
Hi, if you install an Enscape version which supports Revit 2027, Envision should be working fine.
Are you having some specific problem with this? If so, could you please share the details? For example, if there is an error message, please post it here.
Thank you for the quick reply. You were right—I had confused the two. Chaos Envision is working correctly. I was actually referring to Chaos Bridge, which currently does not support Revit 2027.
Thank you!
You’re welcome! :slight_smile:
Feel free to contact us if you need any further help - https://support.chaos.com/hc/en-us/requests/new
So do you know when an update for Chaos Bridge with support for Revit 2027 is coming?
I’ll do my best to get this information for you. :slight_smile:
Sorry, but we don’t currently have a specific release date, and any information about Revit 2027 support will be announced publicly.
Thanks for information.
