Olá, quando vou iniciar a renderização usando IES aparece este erro.
Gostaria de saber o que tem de errado.
Gem::install(‘rubyzip’)
[#<Gem::Specification:0x00000146d04b6370 @extension_dir=“C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Gems64/extensions/x64-mingw32/2.5.0/rubyzip-2.3.2”, @full_gem_path=“C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Gems64/gems/rubyzip-2.3.2”, @cache_file=nil, @gems_dir=“C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Gems64/gems”, @base_dir=“C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Gems64”, @loaded_from=“C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Gems64/specifications/rubyzip-2.3.2.gemspec”, @original_platform=“ruby”, @installed_by_version=#<Gem::Version “2.7.6”>, @autorequire=nil, @description=nil, @email=[“alex@simonov.me”], @homepage=“GitHub - rubyzip/rubyzip: Official Rubyzip repository · GitHub”, @name=“rubyzip”, @post_install_message=“RubyZip 3.0 is coming!\n**********************\n\nThe public API of some Rubyzip classes has been modernized to use named\nparameters for optional arguments. Please check your usage of the\nfollowing classes:\n * `Zip::File`\n * `Zip::Entry`\n * `Zip::InputStream`\n * `Zip::OutputStream`\n\nPlease ensure that your Gemfiles and .gemspecs are suitably restrictive\nto avoid an unexpected breakage when 3.0 is released (e.g. ~> 2.3.0).\nSee GitHub - rubyzip/rubyzip: Official Rubyzip repository · GitHub for details. The Changelog also\nlists other enhancements and bugfixes that have been implemented since\nversion 2.3.0.\n”, @signing_key=nil, @summary=“rubyzip is a ruby module for reading and writing zip files”, @version=#<Gem::Version “2.3.2”>, @authors=[“Alexander Simonov”], @bindir=“bin”, @cert_chain=[], @date=2021-07-05 00:00:00 UTC, @dependencies=[<Gem:
ependency type=:development name=“coveralls” requirements=“~> 0.7”>, <Gem:
ependency type=:development name=“minitest” requirements=“~> 5.4”>, <Gem:
ependency type=:development name=“pry” requirements=“~> 0.10”>, <Gem:
ependency type=:development name=“rake” requirements=“>= 12.3.3, ~> 12.3”>, <Gem:
ependency type=:development name=“rubocop” requirements=“~> 0.79”>], @executables=[], @extensions=[], @extra_rdoc_files=[], @files=[“README.md”, “Rakefile”, “TODO”, “lib/zip.rb”, “lib/zip/central_directory.rb”, “lib/zip/compressor.rb”, “lib/zip/constants.rb”, “lib/zip/crypto/decrypted_io.rb”, “lib/zip/crypto/encryption.rb”, “lib/zip/crypto/null_encryption.rb”, “lib/zip/crypto/traditional_encryption.rb”, “lib/zip/decompressor.rb”, “lib/zip/deflater.rb”, “lib/zip/dos_time.rb”, “lib/zip/entry.rb”, “lib/zip/entry_set.rb”, “lib/zip/errors.rb”, “lib/zip/extra_field.rb”, “lib/zip/extra_field/generic.rb”, “lib/zip/extra_field/ntfs.rb”, “lib/zip/extra_field/old_unix.rb”, “lib/zip/extra_field/universal_time.rb”, “lib/zip/extra_field/unix.rb”, “lib/zip/extra_field/zip64.rb”, “lib/zip/extra_field/zip64_placeholder.rb”, “lib/zip/file.rb”, “lib/zip/filesystem.rb”, “lib/zip/inflater.rb”, “lib/zip/input_stream.rb”, “lib/zip/ioextras.rb”, “lib/zip/ioextras/abstract_input_stream.rb”, “lib/zip/ioextras/abstract_output_stream.rb”, “lib/zip/null_compressor.rb”, “lib/zip/null_decompressor.rb”, “lib/zip/null_input_stream.rb”, “lib/zip/output_stream.rb”, “lib/zip/pass_thru_compressor.rb”, “lib/zip/pass_thru_decompressor.rb”, “lib/zip/streamable_directory.rb”, “lib/zip/streamable_stream.rb”, “lib/zip/version.rb”, “samples/example.rb”, “samples/example_filesystem.rb”, “samples/example_recursive.rb”, “samples/gtk_ruby_zip.rb”, “samples/qtzip.rb”, “samples/write_simple.rb”, “samples/zipfind.rb”], @licenses=[“BSD 2-Clause”], @metadata={“bug_tracker_uri”=>“Issues · rubyzip/rubyzip · GitHub”, “changelog_uri”=>“rubyzip/Changelog.md at v2.3.2 · rubyzip/rubyzip · GitHub”, “documentation_uri”=>“RubyDoc.info: File: README – Documentation for rubyzip (2.3.2) – RubyDoc.info”, “source_code_uri”=>“GitHub - rubyzip/rubyzip at v2.3.2 · GitHub”, “wiki_uri”=>“Home · rubyzip/rubyzip Wiki · GitHub”}, @platform=“ruby”, @rdoc_options=[], @require_paths=[“lib”], @required_ruby_version=#<Gem::Requirement:0x000001 46d04f69e8 @requirements=[[“>=”, #<Gem::Version “2.4”>]]>, @required_rubygems_version=#<Gem::Requirement:0x00 000146d04f61a0 @requirements=[[“>=”, #<Gem::Version “0”>]]>, @requirements=[], @rubygems_version=“3.1.4”, @specification_version=4, @test_files=[], @new_platform=“ruby”, @full_name=“rubyzip-2.3.2” rubyzip-2.3.2>]
Hello @eduardo_boehlgrazia
Please note that the Chaos Support teams operate only in English.
As for the issue itself, I suspect that it might have already been fixed with one of the later V-Ray Next updates. From what I’m seeing, you’re using V-Ray Next, so my first recommendation would be to prompt you to install V-Ray Next Update 2.2 (4.20.03), which is the last V-Ray Next update.
Let me know if this solved the issue. If it didn’t, please use our Submit a Request form, so that we can continue with the investigation of the issue.
Thank you in advance!
