Error: Access violation
Hello everyone,
I have a question.
Since I updated Corona to version 11, I have repeated rendering issues. 3Dsmax is suddenly crashing without saving. That situation repeated very often. Previously I had also that kind of problem but they were not so frequent.
Here is 3dsMaxErrorRaport
Date/Time: 2023-12-14 16:46:20 +01:00
Application: 3dsmax.exe
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name: Corona_Release.dll
Exception Address: 0x00007ffb6c888583
Exception Code: c0000005
Exception Flags: 0
Exception Parameters: 0, 0
Do you have any idea what I should do?
I use Windows 11, 3DsMax2024, Corona Render 11
Best,
Adam
Best is to share more information - see https://support.chaos.com/hc/en-us/articles/4649117083409-How-to-report-issues-3ds-Max- as a guide.
When there is a crash, it is a huge benefit for us to see the minidump, and also to know just what you were doing at the time of the crash. It may also be helpful to have the scene. Note that if you do not want to share those on the forum, you can always open a ticket and attach them there so that only the support team see them https://support.chaos.com/hc/en-us/requests/new
If you can add that info, it would be a big help in diagnosing what is going on. Thanks!
Tom,
Thank you for your advice.
I will follow your instructions
Best,
Adam
Hi
I have the same issue too.
did you find any solution or culprit for this error?
it is my error breif report
Date/Time: 2024-06-26 02:53:11 +03:00
Crashed Module Name: mscorlib.dll
Exception Address: 0x00007ffd0c6a5180
Exception Flags: 0
Exception Parameters: 0, 88
Managed Exception Type: System.AccessViolationException
Managed Exception Address: 0x0000018fd6178ff0
it is the summary of winDbg of minidump file report
ExceptionAddress: 00007ffd0c6a5180 (CoronaMax_Release_2023!LibVersion+0x00000000000998b0)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: 0000000000000088
Attempt to read from address 0000000000000088
PROCESS_NAME: 3dsmax.exe
READ_ADDRESS: 0000000000000088
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
EXCEPTION_CODE_STR: c0000005
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 0000000000000088
STACK_TEXT:
0000005a0e4fb0d8 00007ffd0c6a8a16 : 0000005a0e4fb120 00000190cd58a030 0000005a0e4fb169 0000005a0e4fb250 : CoronaMax_Release_2023!LibVersion+0x998b0
0000005a0e4fb0e0 00007ffd0c6a635a : 0000000000000000 0000005a0e4fb250 000001921edec5a8 00007ffe21eac350 : CoronaMax_Release_2023!LibVersion+0x9d146
0000005a0e4fb1d0 00007ffd59673fd9 : 000001921e1c27c8 00000000000088f8 0000019245d4aa38 00000000000005b5 : CoronaMax_Release_2023!LibVersion+0x9aa8a
0000005a0e4fb320 0000000000000000 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : LegionLib_Release!Legion::isMainThread+0x209
STACK_COMMAND: ~0s; .ecxr ; kb
SYMBOL_NAME: CoronaMax_Release_2023+998b0
MODULE_NAME: CoronaMax_Release_2023
IMAGE_NAME: CoronaMax_Release-2023.dll
FAILURE_BUCKET_ID: NULL_CLASS_PTR_READ_c0000005_CoronaMax_Release-2023.dll!Unknown
OS_VERSION: 10.0.22621.1
BUILDLAB_STR: ni_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
IMAGE_VERSION: 11.2.0.24845
FAILURE_ID_HASH: {cb55f6df-5bed-b417-f9c3-c1e8ea5e20a4}
Followup: MachineOwner
it is the dumpuserinfo.xml
<AppInformation name="3dsMax25" version="3ds Max 25 - 64 bits ENU  "/>
<OpenGLInfo Renderer="Corona" Vendor="Nitrous (Direct3D 11.0 Feature Level 11 - NVIDIA GeForce RTX 3080 Laptop GPU)" Version="11.2.24845"/>
<DotNet CLRVersion="v4.0.30319"/>
<AppCDATA><![CDATA[Command:[Tool- undo, Tools- Hide Selection, Tool- tool hlist, Tools- Unhide by Name, Tools- Zoom Extents Selected]; Redo [spoiler]; Undo [Exit Isolate, Isolate Select, Select, Select, Select, Select, Select, Select, Isolate Select, Select, Select, Exit Isolate, Isolate Select, Select, Select, Isolate Select, Select, Exit Isolate, Isolate Select, Select, Unhide by Name, Exit Isolate, Isolate Select, Exit Isolate, Isolate Select, Exit Isolate, Isolate Select, Exit Isolate, Isolate Select, Exit Isolate,]]]></AppCDATA>
<DeviceInfo DeviceIDv2="D12ED2FA2B359634D55024F21078BCBB120601BD83CBD6128148DF3AFEAA350B&199A7AFA7429207C2F47251F9901204D8488A13E1BF2B860B8033EABD2378777&89607312B7536230EC0E26BCE6727E3EECEFB0EDA2C377E04EE458EE014AAB8E"/>
<DxDiagInfo>
	<SystemInformation>
		<OperatingSystem><![CDATA[64-bit Windows 11 Pro 64-bit (6.2, Build 9200) (22621.ni_release.220506-1250)]]></OperatingSystem>
		<Language><![CDATA[English (Regional Setting: English)]]></Language>
		<SystemManufacturer><![CDATA[ASUSTeK COMPUTER INC.]]></SystemManufacturer>
		<SystemModel><![CDATA[ROG Strix G733ZS_G733ZS]]></SystemModel>
		<BIOS><![CDATA[G733ZS.324]]></BIOS>
		<Processor><![CDATA[12th Gen Intel(R) Core(TM) i9-12900H (20 CPUs), ~2.5GHz]]></Processor>
		<SystemMemory><![CDATA[32768MB RAM]]></SystemMemory>
		<PageFile><![CDATA[82632MB used, 54795MB available]]></PageFile>
		<FullDirectXVersion><![CDATA]></FullDirectXVersion>
		<DxDiagVersion><![CDATA[6.02.22621.3527]]></DxDiagVersion>
	</SystemInformation>
	<GraphicsDeviceInfo>
		<DirectXVersion><![CDATA[12.0]]></DirectXVersion>
		<DDIVersion><![CDATA[12]]></DDIVersion>
		<DDIVersionNumber><![CDATA]></DDIVersionNumber>
		<DxDiagWHQLLevel><![CDATA[1]]></DxDiagWHQLLevel>
		<DriverSignedValid><![CDATA]></DriverSignedValid>
		<DriverSigned><![CDATA]></DriverSigned>
		<Manufacturer><![CDATA]></Manufacturer>
		<ChipType><![CDATA[NVIDIA GeForce RTX 3080 Laptop GPU]]></ChipType>
		<DACType><![CDATA]></DACType>
		<GraphicsHWMemory><![CDATA[24232 MB]]></GraphicsHWMemory>
		<DisplayMode><![CDATA[3840 x 2160 (32 bit) (60Hz)]]></DisplayMode>
		<VendorID><![CDATA[0x10DE]]></VendorID>
		<DeviceID><![CDATA[0x249C]]></DeviceID>
		<SubSystemID><![CDATA[0x147D1043]]></SubSystemID>
		<RevisionID><![CDATA[0x00A1]]></RevisionID>
		<GraphicsDriverFile><![CDATA[C:\WINDOWS\System32\DriverStore\FileRepository\nvamsig.inf_amd64_713c576b7c46e314\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvamsig.inf_amd64_713c576b7c46e314\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvamsig.inf_amd64_713c576b7c46e314\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvamsig.inf_amd64_713c576b7c46e314\nvldumdx.dll]]></GraphicsDriverFile>
		<DriverFileVersion><![CDATA[31.00.0015.5222]]></DriverFileVersion>
		<DriverDate><![CDATA[4/11/2024 3:00:00 AM]]></DriverDate>
		<WHQLLevel><![CDATA[1]]></WHQLLevel>
	</GraphicsDeviceInfo>
</DxDiagInfo>
<VideoDriverInfo>
	<ATIPackagingVersion><![CDATA[No value found]]></ATIPackagingVersion>
</VideoDriverInfo>
[/spoiler]
