I just updated vray from the official version (see sig) to the latest nightly ( 13878 ).
I have a scene with vrayfur that won’t render via command line anymore, this is the log:
it does render in the render view, but still gives the same message:
Error: Can’t find the output parameter for node type: VRayFurSampler
/Applications/Autodesk/maya2011/Maya.app/Contents/bin/Render -r vray -proj /Volumes/projects/uncinc/3D -threads 2 -s 1 -e 1 /Volumes/projects/uncinc/3D/scenes/Rendering/AnimationCacheRenders/CanvasPoses/UNC_Sad_V02.mb
Starting "/Applications/Autodesk/maya2011/Maya.app/Contents/bin/maya"
[2011/Jan/14|12:51:44] V-Ray: V-Ray for Maya version 1.50.SP1 from Jan 14 2011, 07:34:24
[2011/Jan/14|12:51:44] V-Ray: V-Ray core version is 2.00.01
mental ray for Maya 2011
mental ray: version 3.8.1.26, Feb 7 2010, revision 110437
File read in 0 seconds.
Result: /Volumes/projects/uncinc/3D/scenes/Rendering/AnimationCacheRenders/CanvasPoses/UNC_Sad_V02.mb
V-Ray: Starting render
[2011/Jan/14|12:51:47] V-Ray: Loading plugins from "/Applications/Autodesk/maya2011/Maya.app/Contents/vray/vrayplugins/libvray_*.so"
[2011/Jan/14|12:51:52] V-Ray: 100 plugin(s) loaded successfully
[2011/Jan/14|12:51:52] V-Ray: Finished loading plugins.
[2011/Jan/14|12:51:52] V-Ray: Exporting scene to V-Ray.
[2011/Jan/14|12:51:52] V-Ray: Parsing light links time 0h 0m 0.0s (0.0 s)
[2011/Jan/14|12:51:52] V-Ray: Translating scene geometry for V-Ray
Error: Can't find the output parameter for node type: VRayFurSampler
--- Attaching to process stdout stream ---
--- Attaching to process stderr stream ---
