Hello i need help
I have a problem with corona 10 the render appears in this way in another camera within the scene and I cannot find the error, it also appears that way when zooming in on an object with the interactive render
any solutio ??
Did you try to create new camera and see if it renders fine?
Hi, pleaser check your camera Field of View or Focal Length to see if everything is properly setup. Since you are in maximized viewport mode make sure the view to render lock renders the requested camera if on, there are some issues with maximized views and camera lock in the render setup (F10). You can either try and disable the lock or exit maximized viewport and try again.
As for the zooming issues I am not sure I exactly understand what’s the issue can you please clarify?
