Error creating bitmap ???
Can it be right that there is a limit of how hi you can render your image in V-ray , or have I done somthing wrong
This message is put up by 3dsmax, not by VRay. You can avoid it by using the 3dsmax Bitmap pager, or by writing the image directly to disk to a .vrimg file format through the VRay VFB.
Thanks, that solves the problem, thanks again :wink:
