Error creating file output
Have a bug. In one scene if i push button “render” in render setup window then max give “error creating file output” but if i push F9 to render, it’s ok
you have render path set to nonexisting folder in either save render output in common renderer settings, or in one or more render elements.
Thanks! i will try today)
Sometimes this is just Max internal error without setting up any path. I had it qute few times, and I never set any paths.
If this is a case, sample set file output path, hit render, close, then you can delete the path.
