Error: Exception [module=1] : Clearing ray server (freeing resource manager)
Error: Exception : Clearing ray server (freeing resource manager)
What is that?
It is not fatal since it is at the end of rendering, but i would like to know why this could happen…i get it since i am using a large Tiled-EXR reflcetion map…
Which V-Ray version? Can you get me a scene for this?
I am using the official build from Apr 11. I will check if i can get our Admins to switch to a newer version.
I will also try to get you a scene, but unfortunately it is using Shave…maybe the error also occurs without shave…
Another question: Do you think there will be improvements in rendering “Shave and a haircut” using newer builds of vray? Maybe faster rendering?
regards
Oli
There are some general improvements when rendering dynamic geometry like hair and fur, which should affect Shave&Haircut rendering too.
I have experienced a similar problem. The solution was to set the file nodes to have quadratic filtering “on” (the artist has set all filtering to be off by default) and that has caused a similar render exception.
