Error File OutPut
Hi, I have this problem!!Error creating output file ..can you help me?
sorry for my poor languange
radiosity
this is 3dsmax issue, either your file output in common rendering settings, or one of your render elements has the output file set to nonexistent path
It happened here a couple of times too. When you did not assign a output path and you have a couple of renderelements in your scene, sometimes the output path is magically set to some invalid path in your userfolder. It’s totally random so I can’t say when it happens.
thansk!!!
radiosity
