I’m testing today’s nightly build and I get the following error message:
“Error : Ignoring material LPE label “coat”, which is reserved for internal usage”.
How can I find out which material is causing this error ?
Kind regards
algato
Kind regards
algato
Coat is a wildcard for the, you guessed it, coat layer. Simply rename the material named “Coat” to something else.
Getting same error on Backburner using, V-Ray 6, update 1
3dsmax adapter error : Autodesk 23.0 reported error: [V-Ray] Ignoring material LPE label “coat”, which is reserved for internal usage.
Don’t have any material named as COAT, having few cars in the scene which is using VrayBlendMtl wchich has Coat material.
had the same problem here, You need to just rename the VrayBlend coat layer.
Someone with godlike power could write a script for this. That would be great.
@suhit2005 Could you send a simple scene (the shader on a sphere) so we can take a look? It shouldn’t happen if there’s no material named ‘coat’.
getting similar
[21:48:41.326] Error : LPE label m&m’s-2 contains one of the following illegal characters: @’
[21:49:04.157] Error : 1 error(s), 0 warning(s)
[21:57:41.326] Error : Ignoring material LPE label “base”, which is reserved for internal usage
[21:57:41.330] Error : Ignoring material LPE label “base”, which is reserved for internal usage
[21:57:41.338] Error : LPE label m&m’s-2 contains one of the following illegal characters: @’
on checking it further found some sub-object material named BASE and COAT and it is producing error, we have many files containing such objects, it is difficult to change name in each files.
Here’s a simple script that will help you with the renaming. Simply type the material name (in your case base and coat) and add a prefix/suffix of your choice.
MaterialNameAppender.7z (534 Bytes)
I wrote another script for this particular error. It renames only the materials, which use the reserved LPE labels.
EDIT: Made keywords case-insensitive.
RenameLPEReservedLabels.7z (495 Bytes)
We released new builds of V-Ray 6.1 yesterday (February 21st) that should fix the issue; there should be no need to rename any materials anymore.
Thank you very much vlado, I’m testing it right away!
