Error in enscape
What does the error indicate, I am trying to export an exe file from enscape
Hi @Varsha_C,
Welcome to our forum!
This error means the project is too large to create an Exe Standalone from.
This is limited by the Windows Portable Executable (PE); hence, the “Stream length starting position is too large to hold a PEImage” part.
The created exe file is limited to 4 GB, as seen on the Microsoft page here
You can try reducing the project size/complexity, or dividing it up into parts.
Alternatively, you may want to try our 3D Streaming feature, as seen here.
@Rick_Marx1
The previous export, without a couple of the files, was about 800 MB, so I believe the final export should not exceed 4 GB. Could you suggest how I should move forward?
Even if I add one more link after this, it will show the error.
Hi @Varsha_C,
In that case, it is odd that this error comes up then, although issues can already arise after passing the 2 GB threshold in some cases.
We may need some more information, and I would recommend taking this offline so we can take a closer look.
Please send us a feedback report, including the log files as seen in our article here, and change the title of the report to ‘Regarding Case Nr. {{ticket.id}}’ as well, so we may connect the provided data to this thread.
@Rick_Marx1
I have already raised this issue with Support and provided the logs. However, the suggested solution is to reinstall the software, which doesn’t seem to resolve the issue.
I also received a link in the email, but unfortunately, that doesn’t work either.
Thank you for your help.
HI @Varsha_C
I have replied to you in the ticket.
