Error in Render Mask
Happy new year to all!
I guess there is a bug with the render mask and forester for C4D.
On my screenshot only one cube should appear, but the leaves from the tree are rendering. Bucket and Progressive
With forester is still the thing that the leaves appear only at production rendering and not interaktiv… just for your information.
I am using C4D R2023.2.2 / Windows 11 / Vray 6.2
Edit: Even when I convert the forester tree to an object
this is related to the texture you use in the opacity slot of the leaves. Cant remember exactly but either default or alpha from diffuse causes the Problem. Should work fine with standard black and white alpha jpgs!
Hi, great thanks for the tip!!!.. I will try it when I have the option :slight_smile: Thanks
