Since the last update, I can no longer run the VRAY module when starting REVIT.
Here is the error log
Hello Kevin,
It looks like a .dll file is missing from your V-Ray installation.
Can you try to uninstall V-Ray manually, then reinstall it.
If the issue persists, we’ll also need to know if you’re using any specific Revit addins.
Best,
Ana
hello Anna,
I verified, the dll is already in the folder of Vray location
I have already uninstall V-Ray manually, ans reinstall it. the issue still persit.
The only addin of revit,i have, is PyRevit.
thanks
Kevin,
Can you send us your exact V-Ray for Revit version as well as your exact version of Windows. It would be best if you simply screenshot both “About” windows. In addition, the version of PyRevit too (just in case).
Best,
Ana
Please try the recommendation in this post: MSVCP140.dll Error - Microsoft Q&A
It looks like the issue may be caused by corrupted system DLL. Please advise if this has solved the problem for you.
Thanks,
Tanya Dilkovska-Petrova
V-Ray for Revit Team Lead
It works, the problem is solved.
Thanks a lot !
