Standart Material - Matte_Shadow_Receiver
Process Render
Result Render
Hello, Vincent,
I assume you are using the GPU renderer.
Setting up a shadow catcher on GPU will not work if you are using only background illumination. Add a light source instead (Dome light or any direct light).
Kind regards,
Peter
Thank you very much, I have already dealt with this issue.
