I am getting the error shown above during the calculation of the irradiance map. The dr clients render black buckets when calculating the irradiance map. Is there any solution for this?
Regards
Oliver
Regards
Oliver
Could you please check whether all machines have the same version of Vray.
After that - do you have any Xref scene in the scene you are trying to render ?
Are you trying to precalculate/save Irradiance Map ?
Can you reproduce the issue on simple scene, or it exists only for particular scene ?
Which version of Max and Vray are you using ?
Hello - I think I managed to reproduce this issue by accident.
If the render is being canceled during the IM calc. stage render nodes fail to receive IM for some reason.
I’ll log this case into our system and I’ll let you know when we have some updates.
This issue has been fixed for the next official service pack.
