Error Message
Just installed the Corona Renderer on my workstation. I use 3ds Max 2016.
When i go to with the M button I see this (see image).
I set the Corona Renderer as Default.
Wenn I look I see a License Error ?
Regards,
Guus (The Netherlands)
What happens when you use the corona material converter script?
Found the error. When you render for the first time in Corona,
you have to activate Corona.
So the problem is solved. But Corona is so slow ?
I have a dual Xeon 8C station with a K4200 card.
Ands also my machine locks up !
Using Displacement?
Ever since 1.2 the displacement has become unbearable on the RAM.
