ERROR ON ANIMATION SEQUENCE
I’m having trouble when render an animation sequence (.png).
Corona Render stops and I have to resume the render from this point.
Still render works fine.
This message appears:
An error has occurred and the application will now close.
Do you want to attempt to save a copy of the current scene?
Thanks,
Mauricio Duarte.
Is it Alpha v4?
can you send me the minidump file it generates? you can see location of the file in the standard 3dsmax crash screen
Mauricio. Are you rendering over a NEtwork path ?
I´ve stopped to work with PNG on network. Got corrupted files and missing frames from time to time. I am using EXR or TIF instead. Mybe it´s not related to your problem.
Strangely, I recently rendered the animation (75 frames), but in “tga” format, i don’t have error.
I am using Alpha3.
I am going to upgrade to Alpha4 and render same animation for test, OK.
Mauricio.
