I have been getting a lot of crash errors when I exit MAX and now I can’t open a MAX scene that I worked on last week. I tried opening and merging, both just crash MAX. Also, all the autobacks crash MAX, too. Any clues?
Try temporarily cleaning your ENU folder, copy it to a safe place, and delete the original, start max and do your thing, see if it works. Usually cleaning the ENU folder solves a lot of those issues, the thing is you’ll lose all your customizations inside max.
That will not help me get this model open. UGH!!!
Try to merge only a few objects each time to a new file till max crash then you avoid that object/s next time till you merge everything else .
One-by-one and it was caused by one little object. How can a little piece of geometry break a large model and it’s backups.
