Hi guys, I have a problem this morning…
Every time I open 3ds Max I get the folowwing error on the CoronaRenderer_initScript.ms:
– Address: 0x2dc23d9; nCode: 0x00000000C0000005
– Desc: EXCEPTION_ACCESS_VIOLATION The thread tried to read from or write to a virtual address for which it does not have the appropriate access.
– Read of Address: 0x0000000000000078
– MAXScript callstack:
– thread data: threadID:6176
– [stack level: 0]
– In top-level
– C++ callstack:
– (MAXScrpt): (filename not available): HashTable::get
– (MAXScrpt): (filename not available): define_system_global_replace
– (MAXScrpt): (filename not available): install_rollout_control
– (MAXScrpt): (filename not available): AssignToConstError::~AssignToConstError
– (MAXScrpt): (filename not available): command_name_from_code
– (MAXScrpt): (filename not available): FileStream::~FileStream
– (MAXScrpt): (filename not available): escape_checker
– (MAXScrpt): (filename not available): install_utility_page
– (MAXScrpt): (filename not available): LocateScriptResourceFile
– (core): (filename not available): BroadcastNotification
– (3dsmax): (filename not available): Osnap::NumCandidates
– (3dsmax): (filename not available): VertexNormalsControl::VertexNormalsControl
– (3dsmax): (filename not available): NURBSTextureChannel::GetTextureSurface
– (USER32): (filename not available): TranslateMessageEx
– (USER32): (filename not available): CallWindowProcW
– (COMCTL32): (filename not available): CreateUpDownControl
– (COMCTL32): (filename not available): DefSubclassProc
– (AdApplicationFrame): (filename not available): AdColorTheme::ApplyDarkTheme
– ((module-name not available)): (filename not available): (function-name not available)
– (clr): (filename not available): LegacyNGenTryEnumerateFusionCache
– (3dsmax): (filename not available): UtilGfx::kFONT_WIDTH
The only think I did was to delete the VFB+ plugin and I don’t know if is related to this…
Any clues???
Thanks,
Dionysios -
