error saving zdepth
I recently rendered out a few animations and was testing out file formats to save and I had some errors when trying to save TGA or PNG.
The TGA was sent through backburner and PNG rendered straight from the scene.
They saved out the 1st frame elements but failed once it got to the zdepth, which in turned stopped the rendering of the 2nd frame. I wondered if it was something to do with the alpha settings in the file settings? Or if it’s an error with my instal and I just need to do a reinstall?
I ended up saving as a TIFF which worked fine but it would be good to know the cause in case I have to save them out in the future.
I wanted to quickly check if the issue has been resolved or if you are still experiencing the same problem. If the problem persists, could you please provide a scene file along with reproducible steps so that we can replicate the issue on our end?
