This basically happens to me when I render both static and interactive scenes.
I have the latest version of V-Ray: 7.30.00 for SKP 2025
I use GPU rendering
Hello manuel_zarabia,
Could you please confirm if you are using the recommended NVIDIA driver version for V-Ray GPU - currently 581.57?
Kind regards,
Iva
Hi, that was the first thing I did. Then I rendered a new model without any assets, and it worked, so I assumed it was an issue with the assets since the model I was working on kept crashing.
So I found the problem: this Joel Standing 001 model was causing the crash.
It’s worth noting that I upgraded from V-Ray 6.2 to 7.3, so I assume it must be some kind of compatibility issue; however, I find it strange that the asset hasn’t been updated in my case.
Hi manuel_zarabia,
Thank you for figuring out the issue. Could you please confirm if you are no longer experiencing crashes with this asset?
Please note that your local Cosmos Assets do not automatically update when a new version is released on the server. If there is a newer version available, you will see an update button in the V-Ray Asset Editor, and you can manually update it from there.
Kind regards,
Iva
