error: UNHANDLED EXCEPTION: Broadcasting NOTIFY_PRE_RENDERFRAME
error: UNHANDLED EXCEPTION: Broadcasting NOTIFY_PRE_RENDERFRAME Last marker is at ./src/vrayrenderer.cpp, line 4373: Preparing global light manager
3ds max 2018 frequently crashes with the error above showing up in V-Ray messages. When it occurs, is usually always when I click on interactive render. It’s been happening a LOT lately.
It seems like it started when I added a Bercon noise map to VRayDisplacement. I will remove that to see if it fixes the issue.
Thanks.
I can’t reproduce the same error here. Can you share the scene to support@chaosgroup.com so we can take a look? Please mention this thread in the message, thanks.
