error: [VFBCore::SetRegion] Error writing render region to raw image file. [ExrFile::WTRegion] Error writing tile to .exr file
OK so I got this error on 2 different machines rendering 2 different views for the same job. I remember couple of VRay versions back something similar was cause when you set max to render a region. But this is not the case. It is set to render “view” and the view is the VRayPhysical Camera
The job finished render, but the EXR didn’t save the last few buckets I’m geussing. But WHY? Luckily Icould save the VFB as a tga file.
Max 2012 64bit
Max Design 2012 64bit
VRay 2.0 sp1
