So I’ve read through all of the other threads on not seeing Corona on the plugins tab for Cinema 4d, but I can’t seem to find a thread on how to properly install Corona on MacOS for r20…
I used the “Custom” button on the MacOS Corona installation and put it into a plugins folder that I made in my Cinema 4d and then I went into preferences in Cinema 4d and selected that folder for Plugins under the “Plugins” section.
Corona still won’t show up in my plugins section so is anyone able to help? Thanks a ton!
Nevermind, fixed it - I’m an idiot. For anyone who might have this problem in the future: when you hit “customize” on the installer, make sure you select the exact folder that your Cinema 4d application is in. Apparently when I tried installing it I was doing it on the wrong one I guess…
Glad you got it solved, and ty for sharing what you had run into (that always helps for others who may be having a similar problem, and so is better than an “Oh yes, I solved it” post with no explanation on how it was solved - so, much appreciated!)
I’ve notice that the C4D installer does not automatically create a Plugins folder in the app directory. You may have to create it your self, then it will work.
