I wanted to test the new feature to change the assets folder to a network drive and followed the instructions here : Chaos Cosmos
But when I enter the new path and apply I get this error message :
Oops... something went wrong
unknown method ChangeWorkingDirectory for service content.v1beta2.ApplicationStateAPI
Any idea what is going wrong ?
Thank you
Hi theedge,
Please, let us know which Cosmos Browser version you use (you can see it on Cosmos Browser>…>About screen.
Also, send your cb.log file for further investigation. You can find it in this directory: C:\Program Files\Common Files\ChaosGroup\ChaosCosmos
Please, send it to our support team on this link and reference this forum post.
Regards,
@theedge
Could you find a solution for that error? I wasted half an hour yesterday getting cosmos working over network, but no chance!
First I had the issue that the config.json wasn’t writable. I uninstalled cosmos completely and did a new installation.
The writing issue was gone, but the same message as you stated: “unknown method ChangeWorkingDirectory” came up. I even tried changing the json manually but cosmos won’t start that way.
Hi dreidesign,
It seems that for some reason you are using an older version of Cosmos Browser.
I am sending you a link where you can download the latest version: Download | My Chaos
Prior to installing the new version, you need to uninstall the existing one:
1) Uninstall Cosmos Browser
2) Delete from your machine any remains from previous installations. You should delete these directories (if they exist):
C:\Users\<YourUserName>\Documents\Chaos Cosmos
C:\Program Files\Chaos Group\Content
C:\Program Files\Common Files\ChaosGroup\Content
Also, you will need to restart your machine after you install Cosmos Browser.
I hope the above will help resolve your problems.
Let me know if you still encounter issues.
Regards,
Sadly cant download the latest version from that link, getting:
“You have reached maximum request limit.” error
Hi dreidesign,
I am sorry to hear that you encountered error while downloading. This seems like a temporary overload in our download service which our team will look into.
In the meanwhile, please, try downloading again in some time.
Apologies for the inconvenience.
I managed to download the client manually, tested it on 3 machines here and could only make it work on one.
The rest of the machines now got the error “Oops… something went wrong
internal error: open C:\Program Files\Common Files\ChaosGroup\ChaosCosmos\config.json” access denied.
Did all the steps you provied, uninstalling, deleting all the cosmos files in the mentioned directories. Reinstall of client and reboot of machine.
Hey @dreidesign ,
If you haven’t yet, please reach us through our contact form so we can possibly schedule a remote session and troubleshoot on the spot. Thanks!
I already contacted support and we had a remote session. We could find a workaround, but I think there will be some improvements for the next cosmos browser versions.
Sadly I didnt had the time to install it on all our machines to check if it really works when using in a team.
Hi, Having the same problem, tried to install latest browser. Still same error message. What will I do next?
Hi @lube_spasevski ,
Would it be possible to send us the cb.log file so we can have a look? You can share it via our contact form, just make sure to mention this thread (or my name) in the form subject.
Have you tried a clean re-install to make sure that the issue still reproduces? You can try the following steps:
Uninstall the Cosmos Browser, and make sure that the following folders no longer exist once you uninstall Chaos Cosmos:
macOs:
- ~/Library/ChaosGroup/ChaosCosmos
- /Applications/ChaosGroup/ChaosCosmos/
Windows:
- C:\Program Files\Common Files\ChaosGroup\ChaosCosmos
- C:\Program Files\Chaos Group\Chaos Cosmos
Then, please reinstall the Cosmos Browser from the following link and let us know if Cosmos started working:
https://download.chaosgroup.com/?pla…amp;product=62
