Error when converting Corona to VRay
Thanks Lele for the replay, it’s all in CM-M , but this inf.0 value came from old model (i think the value become like this when converted from CoronaLegacy to CoronaPhysical).
The Converter should Solve or Ignore these issues, Better to be Solved by the converter because it’s easy to handle.
I will need the scene that errors out.
for the distance texture bug, the issue is seemingly a bug on our texture’s side, nothing to do with the converter. (VMAX-13603)
This file has both error messages,
Vray Converter Errors.zip (75.4 KB)
thank you!
I know of no way a user can input a value of inf into a spinner.
What converter did you use that produced this result?
regardless, the fix is implemented as a clamp to 1e12 (0.0 for V-Ray wouldn’t work like for Corona.) for incoming values. (VMAX-13604)
It’ll be in the stable builds soon enough.
I don’t remember exactly when that happened (it’s an old file), but I think it’s the “corona converter” (I’m not sure about that).
Would you have the original Corona material? It’d be very helpful for internal investigation.
in Corona Legacy Material you can find some “inf” Spinners, like in the image it shows the “Water lvl” min max.
I know what the limits are, but it’s impossible to manually input the value.
Hence my request for the original material, before being converted, which i renew.
