Error when deploying with ECM
I made a application deployment with ECM for Enscape 4.0.2.11 It keeps erroring out within ECM with “0xfffffff6 (-26)”. I looked it up and its an unknown error. I can run either a powershell or cmd script locally on the machine and it will install just fine. I am following Enscapes online directions to a T and I know that I have all the switches correct in ECM. I can see that ECM copies the .exe and config.xml to the local machines cache but it goes haywire pretty quickly and throws the above error. I also tried pointing the switch to the xml on a deployment share, which also works locally with powershell or cmd.
Has anyone had success with deploying Enscape with ECM?
I get the same error when deploying Enscape with ECM. Did you find any solution?
