Error while exporting proxy meshes
Hello, when I export Corona Proxy I often get this error message: Error: Error while reading the file. Could not extract the required number of bytes from the input stream
Repeating the process eventually gets rid of this message.
Does anyone have this problem?
thank you for reporting, I have a couple of questions:
Does that happen even with simple objects? (e.g. Cube)
Do you mean “Corona Proxy” through File>Export>Corona Proxy or Corona>Corona Proxy?
If you have a scene that this happens consistently with, do you mind sending it over?
Thanks,
Jan
Hello Jan,
it happens with some more complex scenes, and fix is to delete faulty proxy and create new one, then it works, not worst bug but sometimes annoying. Should I come across a reproducible faulty proxy I will share the scene.
Daniel
